Parts of my design not showing up in presentation view
Lauren_Pattison
Hi, currently designing some high-fidelity wireframes for a mobile app I’m working on and I added some svg icons to the nav menu which aren’t showing up in presentation view. Is there a reason for this? And is there any way to fix it so they are displayed in presentation mode? I have pictures of the problem in case they are needed to further clarify what is happening. Thank you.
Best answer by Gleb
Make sure they are placed inside of the frame, and not simply put on top. Check your layers structure, they should belong to the main frame you are viewing.
  • March 9, 2021
Lauren_Pattison
They are all in the same frame, but it’s still not showing 2 of the icons. While not in presentation mode: 1 and then while in presentation mode: 2
Bruno_Figueiredo
@Lauren_Pattison
Any chance you could share the link to your file so we can do a quick check?
You can do it by DM if you don’t want to share it here.
Angel_Pan
Could you fix it? I also have that issue.
Prayer_Bright-okocha
Please im having that same issue, the design is being pushed to one side of the prototype device.
Thank you
Jigme_Wangdi
Yeah. it is because of the layers. Check if the components are under the particular frame
Art_Exhibitions
Mine is nested inside the frame and still doesn’t work
  • September 24, 2021
Hey, sorry to hear you’re having trouble with this.
Are you able to provide a link to your file, so we can take a look?
mia1
  • November 13, 2021
hello, i have the same problem. in the presentation mode the very old versions of the frames are showing, and some frames show a mix of the old and new version. i cannot find anything thats helping and dont know how to continue the work. could someone help? here a link:
mia1
  • November 13, 2021
looks like posting a link isnt possible…
  • November 13, 2021
Wrap it in `` so it’s treated as text or split it somehow so it’s not detected as a link.
mia1
  • November 13, 2021
/file/zMMsBnpDemvdbfEibaPxBr/Massage-App-Wireframe?node-id=0%3A1
mia1
  • November 13, 2021
so you need to put the 3w-point-figma-com
  • November 13, 2021
mia1
  • November 13, 2021
thank you so much Gleb!!! amazing, it works now 🙂 thank you and have a great weekend!
Jason_Diaz
I’m having this same issue and have followed the troubleshooting steps. Not fixed yet
Elufidipe_Tosin
I am having the same issue, the presentation is not showing fully.
Elufidipe_Tosin
Elufidipe_Tosin
@Gleb Pls I need a response
Danisha
This one work for me. Mine component are not in the particular frame. that’s why it is not show at the time of presentation view.
MarcoBCN
Hi,
I have the same issue and while I was checking step by step I realised that in my case is as follow:
until I copy paste in a new page the frames all works fine (I’m able to see 9 screens in the preview) but as soon I start adding links between frames in “Prototype Mode” the amount of screens in the preview changes.
bombadillo
Same 😦 I have to copy-paste things and then they show up. Super frustrating as I don’t always catch it until later and it confuses our teams.
Patrick33
To sum it up, I can only view 5 out of 7 frames in prototype view. At first my 6th frame only showed elements that were on that frame iterations ago. I deleted those elements, copied the corrected frame and pasted it in a new frame with all the correct connections applied. Now nothing shows up for frames 6/7 when I prototype. I am very confused as I am somewhat new to figma.
I have included a screenshot of my prototype but can only include 1 as I am new I guess.
Patrick33
Patrick33
So you just copied everything separately and placed the elements in a new frame? Or did you copy everything at once and place the elements in a new frame? So far everything suggested in this thread has not worked for myself.
