Make it easier for viewers to select nested frames for icons export and layout inspection
Show first post
user564
  • January 20, 2022
你是中国区的朋友吗?我也遇到了和你一样的问题,开发总是和我们抱怨不如其他工具好用,想请问你们最后是怎么解决这个问题的呢?可以留个您的联系方式给我吗,想和您交流一下
RG_man
  • 11 replies
  • February 7, 2022
Same here,
Sometimes using components, the element have more layers.
And when viewer want to select he sometimes selects other elements inside & wrongly export them. Maybe some Lock export icon added to layer. So if parrent group is locked everything under it can’t be selected.
Also this is same for measuring, separate lock option for measuring so it won’t be confused for a viewer what is correct element he need to measure values to, especially when we are using more advance components, variants, etc.
Linda_Pham1
I think the one issue I find with this solution is that we have devs designing for different platforms, and they need different asset types. We’d have to provide each platform its own file type (SVG, PNG, PDF). When an iOS dev uses the Export panel for example, there’s no way for them to filter down to the file type they need. They have to download all file types or spend time unchecking the ones that don’t apply to them.
Alex_Prime
  • 14 replies
  • March 29, 2022
Please vote for this issue, I have am example how the Inspector mode should work
figma-1682
Why do developers need to see the detailed components to the export option? Holding cmd for export option, it’s really hard to download the correct size of assets. We need some alternative better solutions for this.
prabhuatcalypso
There is a simple fix. NAME the main container to be exported as EXPORT, and Just ask them to select the main frame layer named export from the layers panel. You can also use shift and enter to jump out of a frame and select the main container
Wiredframe
  • 7 replies
  • October 18, 2022
Buy why? There’s no need to invert that, it’s just confusing.
Chaine
  • 7 replies
  • March 29, 2023
Current solution for me is to set a fill for the exported frame and make sure the [show in exports] is unchecked, in the meantime lock all elements within the frame, this way in viewer mode even though they clicked on the inner elements, the export panel would still show the outer frame
