Issues importing R plots in SVG format
  • December 6, 2022
  • 431 views
NM1
Hello!
I’m trying to drag-and-drop an SVG plot into Figma
But the result is this:
The file renders wonderfully well in Inkscape and a web browser.
This makes Figma really hard to use in our case.
How can this be fixed?
NM1
  • December 6, 2022
It seems Figma is closing the paths, then filling them with black, and ignoring stroke colors.
The paths are not closed in the original SVG.
NM1
  • December 6, 2022
The issue can be circumvented by:
  • Opening the R SVG plot in Inkscape,
  • For preserving text as text:
    • ungroup all elements (using “Ctrl+Shift+G”)
    • select a text element and select same object type (Edit → Select Same → Object Type, or “Alt+Shift+A”)
    • invert the selection (using Edit → Object to path or “!”),
  • Convert selected objects to paths (using Path → Object to path, or "Ctr+Shift+C).
Having to do this for each plot is really annoying 😕 it would be nice if it just worked…
You can use ggsave with device=svg (Note, not device=“svg”)
