Interactions with smart animate not working as expected when position is fixed and document is scrolled down
smlsvnssn
When using fixed positions, the variant i swap to seems to stick to its “non-sticky” position within the document, and stick to the viewport only after animations have finished. This affects smart animations only.
To reproduce: Create smart animated interaction > Apply fixed position > scroll down a bit, and trigger interaction > experience weird jerkiness 🙂
Nicolas_Lebrun
Hello @smlsvnssn, have you found a fix ? I have the same issue 😦
smlsvnssn
Sorry, no fix, and no feedback from figma on the issue as of yet. Waiting patiently…
smlsvnssn
@Nicolas_Lebrun As it happened, I found a fix just now: Instead of putting the scrollable content directly in the topmost frame, wrap it in another frame, make that frame the same size as the parent frame, check “fix position when scrolling” to true (So that the parent frame has fixed content only), and set scrolling as desired on the child frame. A bit convoluted and hacky, but it works!
Nabil_Amara
Nice, thanks for the fix 👍
Ding_Mingzhe
Genius, thanks a lot 💙
eric.white
Huge thank you! Totally worked to preserve scroll position in overlay with variants.
Farhad_Majidi
Wow! totally fixed it! thanks.
Toni
  • July 12, 2022
Just what I needed, thanks!
Joao_Henrique_Pereira_Machado
Thank you for the fix. Worked just fine now.
