Icons flip after swapping an instance
Reyhaneh
Hi, i try to add icons to an instance, but icons flip every time and i have no idea what cause this problem!
Best answer by tank666
Avokadomos
  • Active Member
  • 377 replies
  • August 10, 2022
This is difficult to figure out without more information. Could you share a design where this happens so that I can take a look at it?
Avokadomos
  • Active Member
  • 377 replies
  • August 10, 2022
Flipping will happen when a frame’s size is reduced beyond 0. If the frame that holds the icon is “crushed” vertically by paddings or whatever, it will not have enough space and invert its height.
Twelve_O2
  • October 21, 2022
Select the main component of that ‘Delete color’ button, after that select icon in the button and press shift + V (it will make flip vertical)
Ricardo_Sunay
This is happening to me too. At first I thought the main component was set to rotate or flipped. But can now confirm its correct at the root, yet it still swaps flipped upside down. Copy and pasting the element into the file works fine. But will not work from an instance swap.
Muhammad_Mehdi
I am having the issue but it horizanttaly flipped
Wiemer_Viet
I had the same issue, for me going to the component of the icon, cutting it, and pasting it again fixed the problem.
Patricia_Pascual
The same is happening to us, too.
The component is all correct at the root, and all icons are the same exact size, yet it still flips upside down when swapping icons.
We have workarounds, but we’re a big organization and we need the icons to work properly out of the box.
tank666
  • 4870 replies
  • March 15, 2023
Anastasia58
The same happens in our company too now, icons flip themselves in buttons. Was the issue fixed by Figma?
gimaf
  • 9 replies
  • July 18, 2023
Been having the same issue all day here: suddenly, icons that were working perfectly started showing up rotated.
Is there any fix?
The proposed solution isn’t working for me. Everything is at 0°
tank666
  • 4870 replies
  • July 18, 2023
Please share a link to an example file.
gimaf
  • 9 replies
  • July 18, 2023
I made a file with the elements that are having the issues (can’t share the original)
Figma – 18 Jul 23
tank666
  • 4870 replies
  • July 18, 2023
In fact, all the icons in the “Link” component are flipped in your file. Pay attention to the Y-coordinates (should be 4, but now 20). Select the icon in the “Link” component and flip it vertically (Shift + V).
gimaf
  • 9 replies
  • July 18, 2023
Thanks, but why did they flip? I haven’t changed them for a while, nobody touched them. How comes I now get this problem?
tank666
  • 4870 replies
  • July 18, 2023
This is what I don’t know for sure. But I can suggest that after all, someone accessed this component and accidentally clicked this shortcut when selecting the icon. I suggest you go through Version History to check the coordinates of the icon in this component.
gimaf
  • 9 replies
  • July 18, 2023
Will do that, thank you
minhyuncho
  • Active Member
  • 20 replies
  • November 28, 2023
나또한 같은 문제를 겪고있다. 매우 곤란…
Arpita1
  • March 11, 2024
This happened to me also, I corrected it by using the below steps:
Go to your main component, click on the vector group and it must be rotated to -90 degree, fix that first and then Shift + V (vertical flip) if needed
