How to replace local component with a library component?
  • November 30, 2021
  • 5 replies
  • 5629 views
Avery
I have a local component in my Figma file. I want to replace that component with a new library component that my team shares. How do I do it? This seems like it should be easy but I can’t find an answer.
If this is not a feature, consider this a request.
Avery
  • November 30, 2021
That video isn’t relevant. The video is about swapping an entire library.
I want to swap single local component for a single library component.
  • November 30, 2021
You can use Master plugin for that:
Avery
  • December 10, 2021
Hi Gleb,
In the video you shared, you show how you replace a local component with a library component. I followed along but got an error.
I selected the component I want to use in the library Figma file and went to Master > Pick target component. Then I went to my working file and selected the component I want to replace and clicked Master > Link objects to target component. It took a couple minutes while Master searched my figma file. Then I got an error saying something like “no components that can be targeted were found”. Any ideas?
  • December 10, 2021
Are there actually any instances of this component in the same file? Since you say it’s local I assume yes but in this case Master should’ve found them. 🤔
If for some reason Master can’t find them automatically, you can use the Similayer plugin to select all instances you need and run Master → Link command again or simply use the Swap Instance menu in the right panel to swap these to the right component.
  • January 9, 2022
