How to prevent drop shadows from showing through semi-transparent objects?
Priscilla
In Sketch, you can create semi-transparent objects, and add drop-shadow to them, no problem. However, adding a drop shadow to a semi-opaque layer in Figma makes it look awful, because the drop shadow shows through, as in the screenshot here:
I found a temporary hack by creating 2 layers: a semi-transparent layer on top, and a fully opaque layer beneath, and superimposing them one on top of the other. The problem, however, is that this style is used throughout the design system, so will become problematic if we constantly have to resize 2 layers for the same object. Is there a way around this? I’ve googled and can’t find anything, except 1 person saying that there’s no way around this, but I refused to believe it, because it seems like such a basic thing. Please help!
Best answer by Phil_Larsen
To reduce the actions required, you could have them be in the same component and have both shapes set to Left & Right, Top & Bottom. That way resizing the parent frame will resize the contents accordingly.
Phil_Larsen
Priscilla
Brilliant! That seemed to work… thank you! 🙏
Phil_Larsen
Glad I could help! 😃
