How to easily select Frame?
  • January 29, 2021
  • 4 replies
  • 9254 views
ouwei
Can anyone tell me the shortcut key to quickly select Frame?
Doesn’t work when I click on the edge?
5
Best answer by Gleb
There are multiple ways you can do it:
  1. Cmd/Ctrl + Right Click or simply right click and use the select menu.
  2. Click the frame name at the top left corner.
  3. Click the frame in the layers panel.
  4. Surround the frame in the selection area: drag from above the top corner to the bottom.
  5. Select something inside and then press Shift + Enter to select the parent.
  6. NEW: Cmd/Ctrl + Left Click the frame (deep select), it will be selected if it has a background.
Personally I use the 2 and 5 methods the most. Since the introduction of #6 I only use it.
Mr.Biscuit
  • 109 replies
  • January 29, 2021
Yup, doesn’t work on a left-click when there are elements inside the frame. But you can use right-click to achieve this, or ⌘right-click if the frame is nested inside other frames.
  • 4708 replies
  • January 29, 2021
yoozer.io
  • 6 replies
  • January 14, 2022
And is there also an easy way to toggle through the frames via shortcut without clicking anything?
  • 4708 replies
  • January 15, 2022
There are different shortcuts for that! End/Home, N/Shift + N, Tab/Shift + Tab.
