How to create interactive component with instance swap icon?
  • September 22, 2022
  • 993 views
Adrian22
Hello! I am a new convert from Adobe XD to Figma, and I’ve run into a couple things that I think should be possible but I have not been able to achieve them.
My app will have several little buttons that have the following parts:
  • Background color
  • Icon
  • Text
Upon tapping each button, the following should happen (within the button):
  • Background color changes to OFF state
  • Icon changes to OFF
  • Icon color changes to OFF
My goal is to create a component where the icon can be instance swapped, and that swap is reflected when the component is interacted with.
I’ve created a link here that illustrates my problem: https://www.figma.com/file/ZuT92N4vVhZeYcYZUpes0g/Instance-Swap-Prototype-Example?node-id=0%3A1
Thanks for your help!
Best answer by tank666
Create a new instance swap property for the icon in the “State=Off” variant of the “Card / Scene” component. Let’s give it a name, for example, “Icon Hover”. Then select the instance of the “Card” component in the “Example” frame, change the “State” property, swap the icon, and change the state again.
tank666
  • 4873 replies
Adrian22
  • 4 replies
Wow, thank you so much! Totally worked 🙂 Appreciate the help!
