How to change arrow size?
  • April 22, 2021
  • 8 replies
  • 12697 views
Hankai
Guyes how to change the size of Arrow? like this
Best answer by Gleb
The default arrowheads cannot be changed. You can only enlarge it by increasing the thickness of the line. You can draw your own with the pen tool.
  • April 23, 2021
Samuel_Nihoul
How can I draw a clean arrow with the pen tool?
  • February 16, 2023
Hold Shift to draw strokes at 45° angles.
This is a unnecessarily complex work around for what is usually a standard function to set the arrow size as a percentage of the line width. Hopefully Figma will put this on the development backlog.
Thomas_Hallgren
That’s NOT cool.
Thomas_Hallgren
A solution. Not a good solution.
  • December 7, 2023
Lol why you so mad about a simple task like this. For rough drafts the default arrows are more than enough. For a real design there are many parameters to arrows: angle, length, width — so you’ll need to create custom ones most of the time anyway. 🤗
Thomas_Hallgren
It would be beneficial if the feature for modifying the arrow heads aligns with CSS standards so that whatever specs are applied are easy to move over to development.
