How I can change Numbers Position Superscript
Omar_Mootamri
Am I able to apply a number position superscript to any number?
I’m experiencing some issue with numbers that are higher than 3
As the example below, you can see that I’ve been able to apply this style for the first 3 description, if I try to apply this to the fourth or any number higher than 3, the panel doesn’t allow me to apply this style.
I would expect that I can apply this property to any number.
Best answer by tank666
Hi @Omar_Mootamri. Apparently there are no other superscript numbers in the font.
tank666
  • 4870 replies
  • June 22, 2021
Jade_Camacho
Hi @Omar_Mootamri , I’m having the same issue but worse, I can’t apply any superscript in any font 😩 , did you find the solution for this?
I would appreciate your help. 🙂
Omar_Mootamri
Hey Jade!
I think that there’s no proper way to solve this issue as @tank666 suggested not all font have all superscript numbers.
The only way I’ve solved this issue is using Inter (that is a google font) that supports all superscripts and then you can use Figma Numbers Position in the type details or copy pasting this characters ⁰ ¹ ² ³ ⁴ ⁵ ⁶ ⁷ ⁸ ⁹ ⁺ ⁻ ⁼ ⁽ ⁾
Of course not the best way to manage the font characters in your figma but it helps to make it consistent.
Hope it helped!
Jade4
  • August 17, 2021
Oh! Ok that really helps, thank you so much! 😊
