How do I use join selection function?
  • February 22, 2021
  • 6 replies
  • 8058 views
Chae_Kwon
I’m trying to join two separate vectors into one so that I can fill in. I can combine the vectors by flattening it but it won’t let me fill in the enclosed vectors. When I go to Menu > Vectors, I see the “Join selections” button but it’s disabled and I’m not sure in which instance I can use this function.
Best answer by Gleb
Join selections simply joins two selected vector points with a line. What you need in your situation is a bucket tool (B). Click the areas you want to fill with it and they will be filled with whatever fill you have applied to the current layer.
  • 4708 replies
  • February 22, 2021
Russell_Neill
This is not the answer. I have the exact same problem. Join options are greyed out.
  • 4708 replies
  • October 24, 2023
If this is not the answer, what is your question? To join two vector points you need to select two vector points first, otherwise the option is greyed out.
  • January 25, 2024
You might try the union shapes option. I thought I wanted join selection when I started, but union shapes provided the functionality I was really after – combining two shapes into one continuous outline while removing any intersecting lines from the resultant shape’s interior.
Russell_Neill
No bueno, bro.
  • 4708 replies
  • February 22, 2024
What do you mean?
