Fix the scroll to offset icons / order
  • October 13, 2021
  • 1962 views
Joost_Meijerink
I repeatedly type the Y offset in the X field. This time I was a bit more aware of why I do it wrong all the time:
  1. The icons both show a vertical spacing icon.
  2. If you don’t look at the icon, the most common pattern would be first X, then Y. In this case, that’s reversed. So I have to check the tooltip to see which is which.
Simple fixes:
  1. Make a new X-axis icon (Simply rotate the Y-axis icon)
  2. Change the order to X Y.
  3. Fire the guy that made this, or didn’t see it while testing 😉
  • November 12, 2021
