Figure is not rounded up
  • December 14, 2021
  • 8 replies
  • 1486 views
angrydaddy
I created 2 same figures and decided to round up edges of both of them
bigger figure rounded up successfully, the smaller one rounded up only from one side
Please assist
video
https: // youtu.be/ em99xlhPxtY
  • 4708 replies
  • December 14, 2021
Try to select the point manually and set the rounded stroke cap for it.
angrydaddy
  • 4 replies
  • December 14, 2021
I did, it still doesnt work, although it says there “rounded” screenshot: https: // prnt.sc/ 22ya0vi
  • 4708 replies
  • December 14, 2021
Maybe there are two points stacked on top of each other? Try to move the end point manually and you’ll see if there is another one under it.
angrydaddy
  • 4 replies
  • December 14, 2021
I deleted figure, created a straight line - made rounded ends, it worked, then i edited it to change corner radius and it resetted cornered ends again, video https: // youtu.be/ kDEqKDn3BbE
  • 4708 replies
  • December 14, 2021
Seems like a bug but as a workaround you can flatten the resulting shape (Cmd/Ctrl + E) and the caps should work. This worked for me. Not sure why it’s not working with the corner radius.
Klesus
  • 237 replies
  • December 14, 2021
I tried replicating the shape and it turned out that Figma rendering endcaps on penshapes seems very unreliable.
I then created the shape from a rectangle instead and the rendering issue went away. See if that works out for you.
Edit: Optional fix: endcaps seem to glitch for some reason because stroke position when drawing is by default set to center. Changing it to inside or outside fixes the rendering.
angrydaddy
  • 4 replies
  • December 14, 2021
Thanks! this helped very much
  • January 13, 2022
