Encapsulate widget with fragment gives an error
Robbe_Keters
When trying to encapsulate my widget with a fragment node, the error ‘attempting to create fragment node’ keeps showing up. I don’t see what i’m doing wrong. Anyone that can help?
 <Fragment>
      <Rectangle width={10} height={10} />
      <SVG
        cornerRadius={10}
        src={`
        <svg>
          <path fill="#ffffff" d="${vertices.map(({ x, y }, key) => {
        </svg>
      < Input
        font={font}
        onTextEditEnd={({ characters }) => {
          setText(characters)
          loadFonts().then(() => {
            setVertices(generateBackground(characters))
        value={text}
        fill="#031037"
        inputBehavior="multiline"
    </Fragment>
mrkimedo
  • 5 replies
  • September 24, 2022
Any solution in meantime ?
tank666
  • 4873 replies
  • September 25, 2022
@Robbe_Keters, @mrkimedo, could you show more function code or explain where you are trying to return a Fragment?
mrkimedo
  • 5 replies
Well I am trying to achieve simple thing, I want to have multiple Ellipses and have only one shown in specific time, by that I mean to set hidden property based on some condition. And now the problem is that I need to have Fragment so I could return multiple components without the need of parent component like AutoLayout.
tank666
  • 4873 replies
I assumed that you are returning a Fragment without having a parent component. Only this way I was able to get this error.
I don’t know if this is a bug in the Figma engine or something else, but you can try contacting support by sending them all the necessary information.
figma.com
mrkimedo
  • 5 replies
Will do surly, thanks on fast answer
mrkimedo
  • 5 replies
  • October 3, 2022
just a little update on problem that we were facing
Robbe_Keters
Awesome, thanks for the update. I eventually just encapsulated everything with a frame and made the width and height dynamic by checking it’s contents, which was a huge pain for something simple.
