Components revert to default style instead of honoring style override
  • February 23, 2022
  • 870 views
SJH
Tried searching for this and it seems like people have this same issue, but the posts are closed before a resolution is found.
I have input fields where the width is overridden, but when hovering, or in “active state” this input field reverts back to its default size. But when the state is “default” or “filled”, it recognizes the override. See attached vid.
Any insight into why this happens would be appreciated. I have built several input fields that don’t do this and I can’t figure out why these are different.
Best answer by SJH
I’ve figured this out. Two elements within the set were not set to fixed width like the master component was. I don’t know if that is a bug or something I should have double checked.
tank666
  • February 23, 2022
Could you share a sample file so anyone can take a look at it?
SJH
  • February 23, 2022
