Collections of artboards in Figma
  • August 30, 2021
  • 1413 views
James_Collins
Hi all 👋
Problem / need
I need to create a collection with different artboards from different projects to present a complete user flow of the design solution on a project level. The artboards from the “collection” need to be editable (not flat images). To visualize my need I created a simple diagram of the structure which I want to achieve. 👇
It needs to work in the same way as the “Collections” on the Abstract.
Potential solution
To push all artboards to the level higher and make them accessible from different projects, I decided to convert needed artboards into symbols and place them into selected libraries.
The potential problem here is the performance. Considering the number of elements on artboards (including a high amount of images) I have some doubts that symbols will be working fine.
Is there any way to handle that? 🤔
I tried to find any information about that, but that was unsuccessful. I found a Figma plugin Connect, which allows me to connect all artboards. BUT, the plugin converts artboards into flat images, which block the abilities of the asset export and inspect mode for devs.
Thanks in advance for all kinds of information!
Regards,
James
Josh
  • Former Community Manager
  • September 10, 2021
Hey @James_Collins thanks for sharing!
In your mockup are the “artboards” single frames or whole prototyping flows?
Are they exactly the same across the different files/projects?
I think you’re on the right track with making them components but I’m curious if it would be better to create individual components (atomic design) that could then be used across the different files and frames.
Would love some more context though to help point in the right direction.
PS Moving this to the Get Help category until there’s a clear feature request/idea for others to vote on. 🙂
  • October 10, 2021
