Change Default Text/Layer Colour option (from #000000)
9jamie
Let’s imagine an interface that has say, a default text colour that isn’t #000000 (in this case, an assigned style for grey-900).
If there was a way to assign the default layer fill on a text layer to be an assigned hex value or document style, it would save so much time and potential error in manually assigning a colour every time a layer is used. It doesn’t even need to be a stored setting - it would be really nice to have in a session.
I can’t be the only one with this problem, right? It takes a lot of energy to have to keep a check on it every time I’m creating a new layer in any given file. It’s made me want to learn how to code a plugin that could achieve this.
tank666
  • 4868 replies
  • May 29, 2022
Use the standard function “Set default properties”.
  1. Select the text layer with the desired fill;
  2. Go to Main menuEditSet default properties;
  3. Try creating a new text layer.
9jamie
  • May 30, 2022
Ohh, you have no idea what you’ve done <3
Had absolutely no idea this feature existed. Unbelievable.
  • August 28, 2022
