Assigning margin values to components
  • August 20, 2021
  • 1160 views
George_Yiakoumi
Hi!
I’ve created an accordion component, something which (quite commonly) is used in an array (let’s say for example an FAQ section with 4 or 5 questions). Unless I’m missing something here my only solution is to drag in the component 5 times (per q&a) and stack them manually above each other in my design… let’s say 8px apart.
I think it would be cool to add a margin-bottom value to a component so that it automatically inherits this ‘snap-to’ when stacking components under each other? Saves us time having to ‘eyeball it’, or ‘nudge it in place’ 1 pixel at a time zoomed in at 800% 😃
Apologies if this is something already supported, I’m new to Figma (but loving it!)
Thanks
George
Constantine_Zuev
Can you be more specific on what is your current problem?
Right now, my go to way of doing accordion is simply using auto layout. Make your sample section a component with two variations: open and closed. Copy closed one and duplicate enough times to fill your screen. Shift-A and here you go. Make it a component too. Now you can use this accordion instance in your mockups. Override one section to open and type your text. I typically create more sections then necessary in case I need to add stuff later on. Just hide ones you don’t use.
This very same logic can be applied to individual questions in each section. Just make one question a component. Duplicate it few times. Shift-A to auto layout. Hide then in instances when you don’t need them.
George_Yiakoumi
Hi Constantine,
Yeah perhaps I haven’t explained it properly but the Shift-A solved my problem!
Thanks
George
  • September 19, 2021
