Adding % values for size and margin/padding
  • September 26, 2024
  • 89 views
al111
Hi all!
At my job, I create a lot of interfaces for completely different industries, these are both small and large projects, and very often I created a lot of variables for different screen sizes. Then every time we argue with the frontend because it is quite long and sometimes difficult to support all the variables. And I even agree with him, if it were possible to set sizes and margins not in pixels but in percentages, this would greatly simplify and, most importantly, speed up the work of both the designer and the front-end developer. You can create truly flexible interfaces.
100%, as in html, will be calculated from the container. We already have auto layout, we just need to add a toggle in the auto layout settings to switch to % (or just have the same option as for line height by default). And then all objects inside auto layout can be specified with % instead of px. And in dev mode, the developer will receive the result in % and will not have to sit and calculate (or I will do it instead 😅) and the result will be a truly responsive interface
  • Figmate
  • 1980 replies
  • September 27, 2024
A post was merged into an existing topic: Allow percentages for padding in autolayouts
  • Figmate
  • 1980 replies
Hey @al111, Thank you for sharing your thoughts on this matter. I appreciate you providing details about your use cases.
I noticed that another community member posted a topic with a similar idea at Allow percentages for padding in autolayouts To consolidate similar suggestions and ensure they get the attention they deserve, I’ve merged your post with that existing topic.
Thank you once again for your contribution. Please do check out the combined thread when you have a moment and feel free to cast your vote there!
