I need to add an Asterisk in the text input component, but its text area is a variant, so I go to its component which is in another Figma file. I go to the text area’s component (via “Go to main component” to make sure I’m in the right place), make changes, publish them successfully, then go back to the needed file and push the Update, it seems successful as it’s not in the Updates list anymore but I still cannot see the actual update in the needed file. Everything is still connected, all updates were pushed and accepted correctly, what am I doing wrong?
Connected components do not update after publishing successfully
Best answer by dvaliao
Hey @Daiva, sorry to hear this is happening!
It’s hard to be sure what may be causing this without seeing your file(s). Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a screen recording (if possible), a link to the affected design file, a link the library file as an editor (this won’t affect your billing), and share both with support-share@figma.com, so they can take a closer look.
