Additional purple outline on new component
  • June 11, 2024
  • 276 views
Obed_Richman
I created multiple components using two design elements, and the two components each have a purple outline. (This is not the dotted out) Does anyone know what the purple outline means?
  • 3498 replies
  • June 11, 2024
Hi there!
Can you share a quick screenshot so the community can better visualise it?
If you are seeing this, this indicates it is a component or an instance. More info here:
With the dotted lines, it is an interactive component. You can get more information in this help center article: Interactive component
If your whole file turned purple outlines, you may have accidentally toggled ‘Outline’ view on. Here’s here to find it to switch it back to the regular view:
View layer outlines in Figma design explains this view in more details.
Hope this helps!
