Figjam default font missing
  • December 1, 2022
  • 1088 views
Toby3
Having an issue where seemingly random installed fonts are showing up as ‘missing’. Specifically the default font used in Figjam is ‘missing’ so I can’t type, write notes in stickies, etc.
In Design files as well some fonts, despite being installed come up as missing and are not editable unless I choose a different typeface entirely.
Any ideas on a fix?
Best answer by tank666
The default font for sticky notes is Inter Medium. If someone has changed a font that is not installed on your system, then FigJam will show a “Missing fonts replaced” notification when editing such layers.
Try creating a new sticky note by dragging it from the toolbar. This way it will use the default font.
And if you want to change the font, you can use my Change Font plugin.
tank666
  • 4857 replies
  • December 1, 2022
  • December 31, 2022
