Hi, eversince the Figma update from 2 weeks ago I’ve been having an issue with the Fontawesome icon component.
I have a button component with an instance of the Fontawesome icon component in it.
I have multiple instances of this button component with each a different icon, which means that I had to change the content of the text so it changes into the glyph of Fontawesome.
But when I update, for example, the scale of the Fontawesome icon component in my button component. The content of all my button instances are reset.
The layer naming is all the same, as it should be so overrides don’t reset. I just noticed it replaces the content of the Fontawesome icon instance once I change a property of the icon instance in the button component.
Could this have something to do with the new “apply instance swap property” update?
I hope I explained my issue clearly, if not. I can add a screen recording.
Thank you in advance 🙏
