When exporting an object, all properties are saved except for the blur, I save them in png
Export blur does not work
Best answer by Gleb
So you are applying background blur to the object and exporting just the object to PNG? PNG is an array of pixels, it can’t have any kind of special effects like background blur. It only contains the color and transparency at each pixel, it’s static. Trying to export PNG with background blur is like trying to print a video on paper, Harry Potter kind of magic is required. 😃 So you can either export with background or use the background blur filter wherever you are using the image, independent of the image, e.g. it is possible with CSS.
