Change pivot when changing spacing with Smart Selection
Stefan_Abrahamsen
One annoying thing when adjusting spacing is when the selection isn’t left aligned.
The way it is now is if you have a group that is positioned to the right in a frame, and you change the spacing to that group, you now have to drag the group to the left/right by the total amount of pixels that you increased/decreased the spacing multiplied by the amount of items in the group (minus one).
Since you can highlight objects in a selection, I suggest you should be able to use this as a pivot with which spacing adjusts to accordingly.
Hopefully this GIF explains it:
The gif demonstrates with the pivot at the center object, but you should be able to do it against any object in the selection.
What do you think?
Be the first to reply!
