Add ability to resize text box height
  • May 26, 2021
  • 4237 views
Anna_Wozniewicz
Standard user behavior (even in such a simple platform) is ability to resize text boxes by both width and height. Feels very limiting right now and as you add more text boxes, you end up with a lot of overlapping boxes because the height can’t be resized after creation.
Kevin_Hoffman
Existing Workaround
Text boxes can be vertically resized using the keyboard shortcut Shift-Command-Up Arrow.
However, I do agree that resizing text boxes using a mouse results in some unexpected behavior regarding the height of the text box.
Current Behavior
Stretching the width of a multiline text box does not cause text box to “hug contents” and instead maintains the original height of the text box regardless of how many lines of text are being displayed.
Expected Behavior
Stretching the width of a multiline text box should cause the text box to “hug contents” (similar to auto layout text in Figma). As the number of lines decreases, the text box should get shorter to match the height of its content.
Kevin, thanks SO much for the response. What a crazy user experience. I can change the width with the mouse, but am limited to a keystroke to change height!
Niklas_Larsson
Yes, almost 2025, and still as crazy.
