Where im my ts code I should declare "command" to map function to the commands from manifest.json?
  • February 10, 2023
  • 6 replies
  • 536 views
Sipilov_Ivan
I want to add submenu for my plugin. I added all items to manifest, like this doc suggests:
figma.com
But there is no example or doc of where these commands should be declare in my plugin code to map them with my plugin functions.
Huge thanks in advance!
Best answer by tank666
if (figma.command === 'menu command string') {
    // do something
Please see this plugin example:
github.com
  • 4873 replies
  • February 11, 2023
    // do something
github.com
Sipilov_Ivan
Hey, thx a lot @tank666
Can you suggest where exactly to declare the if statement? I tried to put it at the same place where I check figma ui message to perform operations based on the UI input. But it doesn’t seams to work.
  • 4873 replies
  • February 16, 2023
Add this condition outside the figma.ui.
Sipilov_Ivan
Yep, that worked with console log, thx. But all my logic and functions for the plugin leaves inside the figma.ui. Can you suggest any solution, how to use it all and not dublicate the hole plugin code?
  • 4873 replies
  • February 16, 2023
Just declare your functions in the global scope and then call them in the right places.
Sipilov_Ivan
Yep, I guess that is the only way. Thank you once again.
