Where has the "Go to main component" button disappeared in assets?
  • April 21, 2023
  • 16 replies
  • 4352 views
nikita_diqsi
Where has the “Go to main component” button disappeared in assets? She used to be, now she’s gone, who knows what this is connected with?
How was it:
right now this is not
Best answer by Eike_J
Same problem here. Also the button “Go to Main Component” in the right sidebar has disappeared.
Edit:
I found the reason: If the library is owned by a different person than the file you are working in, there exists the problem. If the library and the file owned by the same person it works.
Eike_J
  • April 21, 2023
Edit:
jjcm
  • Figmate
  • May 3, 2023
Heya @Eike_J - can you give me a little more info here so I can look into this? You mentioned that if the library is owned by a different person the “go to main component” option isn’t appearing - is that a different person in a different organization, or are they a part of the same organization you belong to?
Eike_J
  • May 4, 2023
Hey @jjcm ,
The problem exists, in the following scenario:
Working File:
  • is owned by customer
  • Customer has its own organization
  • I was added to the file with editor permission
  • This file is working with a design library.
Design library:
  • owened by me/my organization
  • customer is viewer in this file
  • I can edit this file and have owner permissions
In this case i don’t see the button. If i create a new file (owned by me) and link it to my design-library i can see the button.
If I create a new file and link it with the customers design-library (owned by customers organization), then I don’t see the button either.
Hope it helps!
I think the problem occurs when you work cross-organisational with a design-library.
Note:
Support emailed me to tell me that I could see the “Go to main component” menu item by right-clicking on the item - this actually worked beautifully.
Aleksandra17
Hi! Now the button is missing from the menu, which is accessed by right-clicking
vernikr
  • June 6, 2023
This is definitely a bug. Some time ago it wasn’t in the same circumstances. Figma, please fix.
A person gave me an edit access to a file, I placed an instance of my component from my another file. Then I can’t find the “Go to main component” command in right-click menu. Though nothing prevents me from finding it manually, updating and publishing.
same problem here. awhile ago i was able to do this. Now the main component is gone.
rodolfo2
  • August 2, 2023
Same problem here. I own the design system file.
Yesterday, I created a create a new file and applied some components. The “Go to main component” option was available on right click.
Today I opened the same file, but now the option is gone.
@support_team
Paola_Prado
This is happening with me too. 😦
Haru
  • August 29, 2023
Same is happening tome as well. Right click dropdown is missing the Go to Main Component selection.
Schmidt_Joel_Pons_Joel_LPD
Same issue for me. No option to go to main component in contextual menu.
kyleen_sayas
Yes, please bring it (view main component on right click) back, Figma! It’s a big problem for us at work since sometimes the component instance being used comes from a third-party provider. Having to contact them for every single concern/update is counterproductive. 😦
Bryan_Ranzenberger
I experience this but I own all of the Library files as well as the file I am working in… so it is not clear to me why I can no longer Go To Main Component for the Libraries which I own.
itm
  • September 26, 2023
This just started happening, inexplicably a few days ago. It’s happened before — for a few days neither or us (an admin and an owner of the added libraries) could add but not directly edit/go to the main component.
This makes no sense. We have been working with the libraries for months, and should be the users that have this kind of access.
Dustin_Hansen1
  • December 15, 2023
I seem to be having the same problem. On some component instances, I have a “Detach instance” option, but don’t see any of these options:
  • Swap instance
  • Change variant
  • Reset all changes
  • Main component >
Screenshot:
NOTE: the component that is missing the “Go to main component” menu/option is an instance from another library. But these are both libraries that I own.
Any ideas?
r_sh
  • July 12, 2024
We encountered the same issue today. The main component is owned by the same person, and there are no branches or drafts of the file.
Gayani_S
  • August 1, 2024
Hey @r_sh, thank you for reaching out and apologies for the delayed response!
I’ve just created a support ticket on your behalf. Your ticket number is #1082149, for reference.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
