WebGPU API is not supported in the plugin
Yi_Shen
The navigator.gpu is undefined when accessed in ui.html. Is this intentional? I tried running navigator.gpu.requestAdapter() in the developer console and it worked fine.
I’m trying to use WebGPU to accelerate the rendering in my plugin https://www.figma.com/community/plugin/1264600219316901594/
  • 2545 replies
  • January 18, 2024
Thanks for the post! I’m asking internally, so I’ll get back to you if there is any information that I can share with you.
Thanks for your patience.
Reid_Draper
  • Figmate
  • January 19, 2024
tl;dr If you navigate your plugin to a hosted iframe, this will work!
I don’t see this immediately documented in the WebGPU spec, but it looks like undefined navigator.gpu for null origin (window.location.origin) frames. I’ve tested with a hosted iframe, and everything works fine.
Let me know if this helps!
Yi_Shen
  • January 20, 2024
Great! Thank you so much for the answer! Glad to see that there is a solution. I will embed a hosted iframe to run the WebGPU ray tracer.
