Variables not working properly in component instances
  • January 24, 2024
  • 610 views
Hi all - I’m running into an issue with Figma variables and wondering if I have something set up incorrectly. When I change modes on a component set, it works as expected. When I create an instance of that component and change the mode, it only switches over certain elements (x icon and modal background) but not all. Thank you!!
See example: The component set is working as expected then the instance placed above is not working correctly.
  • 2545 replies
  • January 25, 2024
Thanks for the post! I’ve tested this on my end and it appears to be functioning correctly in instances as well. Could you please share the file link with us so we can investigate further? I’d like to check if the component’s mode setting, like “auto,” is correctly configured. You can find more information about this in the following article: https://help.figma.com/hc/en-us/articles/15343816063383-Modes-for-variables#h_01HMCXW0AWV7FCAVTBTXWNMXMM
Alternatively, if you would prefer to keep the file private and not share the link publicly, you’re welcome to contact our support team directly at: https://help.figma.com/hc/en-us/requests/new. When you reach out to them, please add support-share@figma.com to your file’s permission. It won’t affect your billing.
