Show colour variables hex code
James_Lawrie
It would be great if you could see a colour variables hex code when assigning a variable to an elements fill / stroke.
James_Lawrie
  • 17 replies
  • July 26, 2023
Screenshot 2023-07-26 at 11.31.41 am
im_arun949
Currently, Figma allows users to create and manage color variables. However, it would be incredibly helpful to users if we could display the corresponding hex codes for these color variables. Video
Manoj_Kumar
Yeah. In my startup most of the time they refer to a color by hex code. I have faced inconvenience finding it.
  • 4911 replies
  • November 3, 2023
Thanks for the feedback!
We’ll pass this onto our Variables team for future consideration.
Lior_Mazza2
  • August 5, 2024
This will a great improvement to this menu
Hi, this is critical. I have three colleagues with the same problem. Maybe showing hex in a tooltip.
Elena_Tschukes_External
This would a great improvement, especially if you share your design with extern people.
Ian P
  • January 21, 2025
As someone coming in to a team’s design system I’m having to find components and break them or their colors to find some of the details. There really needs to be a way to see this info and compare with a reference/design system component.
It could be a great use of AI to scan your color use or rounding values, fonts or anything else, scan preexisting designs and tell you something like “existing elements with a similar design use this defined color value”, show you can example and let you go with that color. Similarly it could be amazing to let you apply standard components you’re creating to preexisting designs to make them consistent as you go.
Joel Cory
  • July 2, 2025
As an example, Auth0 has a wysiwyg interface for theming their login. I need the hex values from our design variables in Figma.
My current solution to see the color value of a variable is to:
  1. Break the variable
  2. Copy the hex
  3. Undo the break
Rinse and repeat. This is tedious.
