๐Ÿ†• Typography, gradients, Library Analytics API, and Code Connect! ๐Ÿš€
  • 4871 replies
Figma just dropped Code Connect to help map more closely to code, Variables is out of beta(adding typography and gradients), and more! ๐ŸŽ‰
Code Connect Beta: Code Connect is a tool for design systems teams to bring component code directly into Dev Mode. Now, when developers inspect a component, they can see production-ready code snippets from your library.
  • Currently in Beta
  • Enterprise or Organization plans only
To learn more, check out the help center article here!
twitter.com
Library Analytics API Beta: Now, your team can access Figma library data outside of the app, so you can organize the data based on your organizationโ€™s needs. This will include component insertion, detachment, and instance data, as well as team and file-level breakdowns.
  • Enterprise plans only
m.str
  • April 16, 2024
Very nice!
Any info when code connect will support Angular?
stacy.kim
Thank you so much for the great information! ๐Ÿ˜
I think you added another link regarding the typography variable update.
What you added was an article about variable fonts, not typography variables.
Baptiste_DANTAS1
Okay, and I think itโ€™s related, but my devs canโ€™t see the variables associated with the colors (they donโ€™t have DevMode).
Can you confirm that this is related?
gimaf
  • 9 replies
  • April 17, 2024
Hi! How can I apply a % line-height? It doesnโ€™t seem like numbers variables support %, am I correct?
Greg_Soper
The โ€œhelp articleโ€ link for font variables is linking to Variable Fonts - highlights the unfortunate naming overlap between them!
Bound to cause lots of minor confusion as designers need to specify which theyโ€™re talking about ๐Ÿ˜‚.
Brown_Jacob
Anyone else having issues with font-family variable? Iโ€™m using two modes. When applying the font family, it appears the tag is updated when switching variables, But visually the font will remain the same until I start to type into the field. Any work arounds for this? Iโ€™d like the font to update without typing into the fields.
The other variables work flawlessly, Iโ€™m able to change font-weight, font-size, line-spacing, line-height, between layers, frames, sections and pages without issue.
