Toggle layers inside a compoent with a boolean variable?
  • December 14, 2023
  • 682 views
Zlatko
I have a component that has two layers on top of each other. Is it possible to turn one on, while the other is turned off (and vice versa) with a boolean variable?
To top it off, can I have multiple instances of that component inside a frame, and change the variable mode so all layers‘ visibility can be controlled through that main frame?
Nate_G
  • 180 replies
  • December 15, 2023
@Zlatko Here is a quick example of one way to set up something like that using boolean variables + modes.
Get the File
Zlatko
  • 38 replies
  • December 15, 2023
Wow, this is really hellpful. 🙏 It confirms what I was trying to do it myself this morning.
I‘m working on a floor plan framework in Figma, and these switches are a game-changer to produce furniture in different styles with showing on/off different layers.
Nate_G
  • 180 replies
  • December 15, 2023
@Zlatko That’s a fun idea, best of luck on that project!
