Text layer preview bug in dev mode
Mickey3
Sometimes, when I select the text layer in dev mode, the preview does not appear. The attached screen is the screen when the same text layer is selected. Sometimes, the preview doesn’t appear like the one on the left. In that case, if you select a different layer and then select the previous text layer again, the preview will appear fine. Is it because I did something wrong? Or is it just a bug?
  • 2545 replies
  • October 8, 2024
Thanks for reaching out. I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
  • 2545 replies
  • October 9, 2024
This was flagged as a bug and our engineering team is working on a fix. We will let you know once this was solved!
  • 2545 replies
  • October 9, 2024
It looks like the issue has been fixed! Could you try again after reloading the tab? I just tested it, and everything seems to be working properly now.
