Yesterday color and text styles would always show as “Text color / Primary” etc in the UI. Now it only shows the last name, “Primary”. This means a selection could show many different colors and they are all named “Primary”. Tried restarting Figma, but it did not help. Is this a new feature? Is there a option somewhere to show the entire style name?
+1 same happening for text styles. I used to be able to see “Body / left” and now i only get “Ag / left” not able to recognise the style until i open the dropdown. if this is not a bug is pretty annoying imo
Yeah this is brutal for our design system — for Color Styles (since we relied on those buckets for theming), but especially for how we handle Text Styles. We organized the different weights of our body text styles by size and now the UI is unusable…
For example: rather than seeing “Text M / Regular”, now you only see “Regular”. So you need to open the picker to see what size you’re actually using. Feels like a regression and hoping it’s something that can be rolled back or at least an opt-in setting.
In general, would be amazing to have even just a few days heads up on changes like this, today is going to be brutal answering questions from our team and trying to figure out how/if to address.
Not sure if the previous way was the best either since it could be hard to read sometimes as wel but I believe something along these lines would be much better
Had to read this topic to realize the change, but it’s not welcome! Except if that means design tokens will be better supported, it needs to be rolled back. A better visual management of styles hierarchy would be welcome (more room to display styles names, better visual separation of folders…).
And in general a heads-up before changes is a minimum (don’t get me started on the library-sharing changes that were quietly pushed recently).
We noticed to and now we have to rename all the styles to make it usable again. I could understand that this could help in some cases. But not if you already used it the other way. For us it’s better to redo this change @anon21722796
In hindsight, it’s the same naming convention as the components (a component instance inserted in a file only displays the last level of the folder hierarchy). There’s some logic to it, and it can make things cleaner, but that means changing previous naming paradigms.
One more confirmation for the Fimga team. This change really confused our entire team and makes it really hard to work with shared text styles. Appreciated if you could explain if this is intended or just a mistake? It also seems impossible to currently change or remove a Text Style from the group it is in.
This is a general issue with Figma. We build stuff specifically within the system but then they make a fundamental change that totally breaks the previous one (and it just pops in without any heads up or anything). Dunno, I get that some of this is par for the course but so many instances where I invest tons of time getting things set up and then a few months later have to redo everything to match a change that didn’t take into consideration how much pain it would cause users. But anyways, yea upvote for this - we need a reliable way to both organize AND view styles.
