[solved] Is there a way to set variable and change to different variant of a component at the same time?
  • December 8, 2023
  • 1331 views
Lisa8
Dear Figma community,
I’d like to do two actions on click of a checkbox:
  1. set a variable to increase a counter
  2. change the component variant to a different variant that has a checked checkbox.
Just looking at the interface Figma seems to allow me to do this and add the change to. However when I try to change the status from “default” to “selected”, it automatically switches back after I select “selected”. Why could this be? Does anyone have an idea?
Thank you for your help!
Update: I got it to work by removing and adding it back a few times. Not sure what happened there.
Max_Humberstone
How did you get this to work? I’ve tried deleting and adding many times but it just keeps switching back to the current variant.
Lisa8
  • December 13, 2023
I frankly don’t know, I tried out many many times of removing and adding back and at some point it worked. I think it also had to do with the order in which I added but just assumptions.
itm
  • 4 replies
  • March 10, 2025
I’ve found order matters. Some actions cause later ones to be ignored. My best practices though I’m not sure if it’s a foolproof solution is to always have variables set before I do anything else (open overlays, navigate to, etc.)
