Slice and Export
  • February 21, 2022
  • 7 replies
  • 2327 views
Jason15
Hi, Im trying to slice and export. But the layers and elements arent showing/exporting.
Please help advise what I’m doing wrong?
Mojo
  • 67 replies
  • February 22, 2022
Figma can export anything within a frame selected, but from your picture, seems that you have your content in difieren frames or layers, and you are only standing on the one that has the header and button, so you want to export everything? Or just specific elements, for example, if you want the button, step on the button wrapper and export that, or if you want the entire screen, check that everything is grouped and export that wrapper
Jason15
  • February 22, 2022
I want the entire selected screen, not just specific elements. I’m an amateur, and had someone create this template for me, so unsure how to group it correctly to export the area.
Mojo
  • 67 replies
  • February 22, 2022
Click and drag from outside your design to draw a rectangle, so you select all the elements, then hit command + shift + g (will create a frame wrapping everything) now select this frame and on the properties on the right you should be able to export everything
Jason15
  • February 22, 2022
unfortunately that didn’t work.
I’m able to use that tactic on other sections, it will grab all the layers in the screen I’m trying to slice. That top screen in the screenshot it will only grab the select layer. It must not be grouped together properly or something.
Mojo
  • 67 replies
  • February 23, 2022
Share a folder structure screenshot of that screen (left panel)
Mojo
  • 67 replies
  • February 23, 2022
Or share the file or a copy, I can help better
Jason15
  • February 24, 2022
ok, i found a workaround but its not precise.
here it is https://www.figma.com/file/3xnse420CwEyYFCKLqaloz/YogaStrong
