Replace a layer with component
harsha20599
We recently migrated into Figma and imported all our sketch files. I created a solid DS in Figma. Now the problem is, while working on old files, It’s hard to remove a layer and place the component at the same place.
It’s been so much annoying and it’s a life saving feature to have something like replace layer with component.
Do you also faced same problem ? Please help me out if you have a workaround or plugin that eases this.
  • 4710 replies
  • February 17, 2021
I made plugin Master to solve exactly this problem (and some more). There are some other plugins with similar functionality but assuming you want to replace “real” layers (not just rectangles or other placeholders), you want to save data and overrides in them, which only Master can do. Here is how to do it:
  1. Select the component or instance of the component you want to attach the layer to.
  2. Go to Master → Pick Target Component. Master remembers this component.
  3. Select layers you want to replace with the component and run Master → Link Objects to Target Component.
Here is a video showing all Master plugin capabilities in action:
harsha20599
  • 14 replies
  • February 17, 2021
This is a powerful plugin for sure. But I am currently looking for even more simple approach like the Component Replacer. It’s actually deleting and placing a new component. That works half way but I am looking for direct replacement.
Nathan_Manousos
Hey I just submitted a plug-in that does exactly this (if I understand your situation correctly), it takes several days to be approved but I’d love to share it with you when it is.
My plugin turns the selected layers into an instance and creates the main component at the root level of your page. It handles all kinds of tricky cases like layers spread between multiple containers, and maintaining constraints from the child to the instance.
If you’d like to beta test it I can arrange that.
  • 4710 replies
  • February 18, 2021
What’s the difference between direct replacement and deleting and placing? This is the only way replacement can be done.
harsha20599
  • 14 replies
  • February 18, 2021
Yes, the only drawback of that is, it places that instance on top of all the layers. I have to manually adjust the layer position. That’s the only drawback.
harsha20599
  • 14 replies
  • February 18, 2021
That’s great and I’d love to test it.
I am looking for something like
  1. I select a layer
  2. Open plugin and search for component from my library
  3. I click on save and that instance is replaced with the selected layer.
Nathan_Manousos
Ooh ok, I think your use case is different than what my plugin provides, but I think there are a few others which attempt to do that. They should be able to insert the new instance right where the selected layer was too.
Altair
  • July 2, 2021
Hello @harsha20599 , did you find a plugin? I need to replace many (background) Frames into an existent (background) Components and this is really annoying
harsha20599
  • 14 replies
  • July 10, 2021
I’m sorry Altair. No luck until now. I Hope @figma comes up with a solution for this!
Maddy
  • October 6, 2021
Did you find a solution? As of right now I am grabbing the component I want from my linked library, then selecting the layer/group I want to replace, and using the new “Paste to replace” feature
  • 4710 replies
  • October 7, 2021
Maddy, this is the best way to do it as of now if you don’t care about keeping overrides.
moenen
  • November 30, 2021
Unfortunately Master doesn’t work when you try to replace an object with a component from an external library.
  • 4710 replies
  • November 30, 2021
It should. Select a component published to the library, run Master → Pick Target Component. Then select objects you want to replace and run Master → Link Objects to Target Component.
If something isn’t working, send me an example here or to gleb@dominate.design so I can investigate what could be wrong. A video recording of your actions and links to files would be perfect.
Alex_Fedorov
I love Figma but goddam if they couldn’t just include a Replace… or Replace With… in the right-click menu like Sketch.
Sarah19
  • January 28, 2022
Our team is planning a transition to Figma, and I’m coming across this issue over and over as I rebuild our pattern library. Replace with... is one of the primary features I use for curating and building components in Sketch, so this is a huge friction point for me.
Figma—please tell me this feature is in the works. 🙏
Brad_Ruesch
@Sarah19 Check out Figma’s “Paste to Replace” functionality. I think this will help. Here’s a link to the Copy and Paste Playground Figma Community file:
Figma
Play with the examples to get the hang of it.
Sarah19
  • February 8, 2022
Thanks! I did discover this tool and it is helping.
Fang_Gao
  • February 15, 2022
The paste to replace doesn’t work if it’s a group / frame to be replaced right. It only works with image I guess. Is there a way that I can replace a group in a component? Thanks!
Fabian
  • February 16, 2022
I just released a plugin, where you can select a frame and replace it with a component and keep the original text from the frame. Only requirement: The original frame and the component must have the same amount of text-frames:
Figma
This Plugin also helps of you want to reattach a detached instance of a component.
Miki_UX
  • February 28, 2023
Hey Harsha, same problem: needed to replace a hundred components. Lucky thing is that they all have the same name. What I did is:
  1. Searched for that layer name, results showed
  2. I copied the component that will replace them (make sure it has a different name than the ones to be replaced)
  3. And then I just pressed cmd + shift + R until all the components in the results were replaced.
Manual, but worked for me in a matter of seconds. Hope this helps, thanks.
Dominic
  • 41 replies
  • March 21, 2023
Using Select Layers plugin is cleaner… not promoting it, just is and it’s free:
  1. Copy your component
  2. Select all (cmd/ctrl + A)
  3. Run plugin called Select Layers - Select Layers by Name, exact match checked (or select any relevant category)
  4. Step2 selects all relevant layers, then simply cmd/ctrl + shift + R to replace all those layers.
Note: sizing and location have to be identical for replacement to be clean. Set your object/component how you want it before Step 1, then copy it.
