Hi , Could you any one tell me short cut key or process to remove white background or transparent cells to get only image in Figma . Hope you understand the my problem .
ex img attached .
Thanks in advance
ex img attached .
Thanks in advance
Menu ⟩ Object ⟩ Remove fill
Mac: Opt + /
Windows: Alt + /
Hi tank, Thanks for your replay . After pressing shortcut key or Remove fill then image also invisible . Tried with this attached image and different images same result losing imaes also completely .
Do you want to remove the background from the image? Then you can use a mask or plugins, for example, Remove BG.
Hi again , Thanks for response . May i know how can you remove the bg in attached image. You given good plugin but in designeing that plug in pricing very high even in learning .
I do not see your attached image.
Figma also has a global search where you can find any other plugins for removing backgrounds from images.
Hi , I am attaching images links here, Actually removing bg for this kind of very easy but i forgot how to do that . If i paste below images i can see these bg white or transparent cells .
thanks in advance.
Perfect , thanks for sharing
