Quickly go to last visited page and back
  • February 22, 2021
  • 77 replies
  • 16749 views
Mads
Clicking between two pages is inconvenient – there should be a hotkey for that.
Context — I have components in Page A and need to see the changes I make on Page B. I make lots and lots of small iterations to my design and want to swap between Page A and B quickly to see results.
Solution — A back and forward button (or hotkey) that let’s you jump between pages you’ve last visited and forward again.
  • February 22, 2021
Mac: fn + ↑ or fn + ↓; or Page Up or Page Down;
Windows: Page Up or Page Down.
Mads
  • February 22, 2021
Works with 2 pages.
Doesn’t work with 16 pages.
  • February 23, 2021
In this case you may have found a bug. Report it to Figma support team via support@figma.com or the support request form.
  • February 23, 2021
@Mads wants to see a new feature, like the “Return” button on the TV remote. That is, if you went from page №3 to page №15, then pressing the shortcut will take you back to page №3, and not to 14 or 16.
Mads
  • February 25, 2021
@tank666 Yes, exactly.
@Gleb Sorry, wrong choice of words on my part. It does work, it’s just inconvenient.
I know this is not an essential feature. It’s a nice-to-have—if you spend multiple hours in Figma every day.
Please move thread back to ‘Product ideas’ and unsolve.
  • February 26, 2021
Moved and renamed to make your idea more clear.
de_la_Puente_Pantoja_Alberto
The problem: The “back to instance” button its really really helpful but in big files sometimes the navigation trough pages is hard and I feel lost. Something like this comes to my mind *Page A > Go the the master on page B> edit it > you look something, edit it > then you try to find the component to back to the instance in Page A.
The solution idea: A back and forth navigation buttons in the header (or any place). Similar to Spotify navigation button.
The back button could take you to the previous page.
Do you think we need something like this?
Thanks.
  • September 10, 2021
When you click “Go to main component”, at the bottom you will see “Return to instance”. Then after editing this component it will still be there if you select the component itself and not something inside of it. Does that help in your case?
Hey Gleb. Nice to meet you.
Yes, the button “Return to instance” remains always on the master component I came to edit. But the problem here is that the component I came to edit doesn’t remain in my brain. 🤣 So I have to find it.
A simple back button between pages and documents could simplify the navigation. Maybe a shortcut (ie. Cmd+Left) could help too.
Afiq
  • September 14, 2021
Could we have a back and forward button on Figma? That would really help to navigate inside Figma file with many pages and designs. The scenario is when im jumping between many pages and have to remember what was the previous page I was in.
Jari_Sanders
Very much agree with @de_la_Puente_Pantoja_Alberto and @Afiq. The example @Afiq shared from Slack is the reason I realized I was missing the feature in Figma actually.
Ideally this feature would also work using the same CMD { for previous page or CMD + } for next page.
I’m aware I can use keyboard shortcuts for navigating through all of my pages, but given that some of my files have more than 20 pages, and it takes a while to load a page I don’t feel like browsing through all of my pages to find the page I was in previously.
thom_s
  • October 11, 2021
I like Return to Instance but I find navigating page to page or node to node can often get quite tiresome panning to / fro.
My suggestion is to include pagination in the toolbar to help combat this, like navigating threads and channels, history in Slack or like we have on the Community dashboard.
Does anyone else experience this?
Lucian_Novosel
+1 I totally need this! Have you found any plugins that do this currently? It might be the next one I make.
thom_s
  • October 11, 2021
Thanks Lucian. None that I’m aware of. It would be quite something if Figma did it themselves, however you’re welcome to give it a go using your nifty plugin keyboard shortcuts 😉
Marc_Nothrop
Definitely agree – I miss this feature many times a day, following links between pages and files, viewing Master Components etc – another feature I miss from Sketch + Runner Pro.
Ben_Picard
  • October 15, 2021
+1 for this. Not just for components though. I do this with coping and pasting elements from page to page
Fabrice
  • October 26, 2021
Same problem here. Going back and force between pages quickly becomes a pain when the number of pages grows. You need to remember the name of the page you’re coming from, and then look for it again in the page list. A trick that helps me a bit is to put an emoji (this one ⌛) in the name of the page I’m working on, so it a bit easier to spot in the list.
Dan
  • November 19, 2021
+1 for a Slack-like back and forward navigation that can move you between not only pages, but tabs in the order you visited. This helps when working across contexts to ensure consistency.
Chere_De_Koh
It’s also an accessibility thing 🔔
I can’t be the only ADHD’er working in figma 😂
I legit need this for those Patrick Star kinda days, per the attachment
Oddly it was never a issue with Adobe InDesign somehow, the visual pages navigator probably was a big part of that 🧘
Gino_Rodrigues
My usual workaround for this is to chose any ubiquitous element (like a logo on a navbar component) and add to it a “Key” interaction (I use backspace) firing the “Back” action. It’s obscure but works, and it is easy to learn.
imikelic
  • January 27, 2022
Great idea and huge time saver. Especially usable for files with lots of pages to quickly navigate back and forward thru pages. 🔙 ▶️
  • February 10, 2022
I’ve made a suggestion to combine navigation and selection history, let me know what you think of it: User Preference to include or exclude object selection in undo - #10 by Gleb
Richard_van_Laak
Alt ← and Alt → currently are used for adjusting letter spacing, but how often does that get used in comparison with going back and forward between previous edit locations?
Imho using these shortcuts for navigation to previous edit / action locations is a no brainer, because the shortcut then would be useful thousands of time per day.
joshmillgate
Really need this feature, one of my biggest pain points in Figma. Especially in a design system with lots of pages and components. I quickly want to be able to go ‘back’ to the page I was just on.
Petru_Strimbeanu1
Switched to Figma from InDesign. And I often press CTRL+PgUp for previous place and CTRL+PgDn for forward. Very useful in InDesign and I’m missing that very much in Figma.
