Preview bugged
Ive a project in Figma, that dont get the correct display when I run the preview, as can be seen in the print bellow, what can I do to correct this?
Edit:
It happens when I run with some items inside this main white frame, if I run outside of it, runs normally
Gayani_S
  • 2081 replies
  • March 20, 2024
Hey @AnakonStar, thank you for reaching out!
Could you please check if the objects or the frames are nested in the Top level Frame?
In my first screenshot you can see that I’ve placed the rectangle outside of the Top-level frame and that’s why the rectangle was not visible in the preview.
If this is not your issue and your objects are nested in the Top-level frame can you clarify this “It happens when I run with some items inside this main white frame, if I run outside of it, runs normally”.
Without adjusting the layers panel are you seeing the objects inside and sometimes outside of the layers panel?
If possible please share a screenshot of your layers panel. Thank you in advance!
