Plugin won't connect to API
  • March 15, 2024
  • 1487 views
Hello!
I am trying to hookup a plugin to an API.
Basically, I am extracting the local variables from a Figma file and I want to store them in a database. Thus far, I am able to get the variables to my codebase.
I have also built a simple API that adds a row to my database. I know that the API works because I have tested it in Postman and get the expected response.
The function to use this API call in the code looks like this:
async function sendJSONToDB(files) {
  console.log("in download"); // this prints, so I know I have entered the function
  const response = await fetch('http://localhost:3000/api/v1/addColorsRecord', {
    method: 'POST',
    headers: {
      'Content-Type': 'application/json',
      'Access-Control-Allow-Origin': '*'
    mode: 'no-cors', // new line
    body: JSON.stringify({
      json_data: files.json_data
  console.log("past fetch") // this does not print, so I never get past the fetch call
  const data = await response.json();
  console.log(data);
Where “files” is an object that looks like this:
let files = {
      json_data: "{}",
      type: "DOWNLOAD"
The API function I am calling looks like this:
//POST Method
const addColorsRecord = async (req, res, next) => {
        let conn;
        console.log("in addColorsRecord") // this does not print, so I don't even enter this function
  try {
	conn = await pool.getConnection();
	await conn.query("INSERT INTO COLOR value (?, ?, ?)", [null, req.query.json_data, getCurrentDateTime()]);
    console.log("something has happened")
        const newColorEntry = {
            json_data: req.query.json_data,
            created_on: getCurrentDateTime(),
        res.json(newColorEntry);
    } catch (e) {
        next(e);
router.route("/api/v1/addColorsRecord").post(addColorsRecord);
So, any help to figure out why the fetch call is not going through would be much appreciated!
Thanks!
  • March 16, 2024
What error are you getting? Did you set up CORS on the server to allow access from any origin (which is null in the plugin)?
  • March 16, 2024
Hi @Gleb that’s part of the weird thing… there is no error… it just seems to exit…
That being said, per your other point, I was getting the classic CORS error:
Access to fetch at 'http://localhost:3000/api/v1/addColorsRecord' from origin 'null' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
But I added in the lines:
    headers: {
But now it just never makes it.
  • March 17, 2024
