New feature wish: Delay option for "on hover" event
  • October 9, 2021
  • 7 replies
  • 4430 views
Axel1
I like to add a feature to the wishlist:
The hover event is very “aggressive” and reacts instantaneously. I have an accordion which expands on hovering. However, it makes it hard to scroll the entire list.
I wish I could set a delay time for the “on hover” event which serves as a sensitivity setting. You would need to hover over a specific object a certain time (= user setting in ms), before the event is actually triggered.
This would be absolutely fantastic and is hopefully not hard to implement.
  • 4710 replies
  • October 10, 2021
A simple workaround is to use the Mouse Enter trigger and add the delay to it.
Then use the Mouse Leave trigger on the hovered element and “Back”, “Close Overlay” or “Change to” action depending on what the first connection was.
Axel1
  • 15 replies
  • October 11, 2021
Thanks for this tip!
I used the mouse-enter and mouse-leave events instead and it worked almost perfectly. But now I encounter a new issue:
The mouse-enter event uses a time-delay of 600 ms whereas the mouse-leave event does not have any delay. When I move the mouse from one just expanded card directly into another (collapsed) card with no white space in between (border touching border), the card which just expanded should collapse immediately and the card just entered should expand with a little delay.
Instead, the old card stays open until the new card is expanded and only then the old card collapses. This behaviour was not intended and it seems to me that the delay for mouse-enter event delays “everything” but should actually not affect the animation of the other component, for my understanding.
If I move the mouse to the side and not directly into a new interactive card, the mouse-leave event is executed as expected: the old card collapses immediately.
The mouse-enter event with its delay seems to be executed before the mouse-leave event can be executed but the two events should be executed independently, I think.
  • November 10, 2021
Danny_Hope
  • March 4, 2023
tl;dr: I tried this and it flickers – see vid.
I had a similar issue. The mouse enter delay bit works perfectly, but
  • moving the mouse pointer without leaving the initially entered element causes the overlay to close and reopen
  • moving the mouse pointer outside of the initially entered element, likewise causes the overlay to close and then open and stay open
  • you have to move the mouse once more outside the initially opened element in order to close the overlay
  • 4710 replies
  • March 5, 2023
The problem is that you are using an overlay. You either need to use Interactive Components or regular Navigate action as in my example.
Maximilian_Hennebach
Also missing this feature.
EdiR
  • May 2, 2024
Very much also want to have this feature. It’s kind of basic thing to have for tooltips and such. Workarounds with mouse-enter & mouse-leave are not realiable.
This is such a basic feature that’s missing that I always think first that I’ve somehow forgot where to toggle this on 😃
