Need Help Removing File from Figma Someone's Shared Tab
  • November 11, 2023
  • 1017 views
User A is the file owner and shared the file with User B. After User B viewed the file, it now appears in the “Recent” section under the “Shared” tab. Despite User B’s attempt to remove the file from the shared tab, Figma displays a message stating, “You have no permission to delete the file forever.” It’s worth noting that User “A” cannot see User “B” listed as a collaborator, yet the file remains visible in User B’s shared tab. How can User B remove the file from both the “Recent” and “Shared” tabs?
It seems like there might be a bug or an issue in the permissions system. Has anyone else experienced a similar situation?
Your insights and assistance would be greatly appreciated!
Thank you in advance!
  • 4710 replies
  • November 11, 2023
  • February 11, 2024
I am facing the same issue. I have removed the acces . yet its in user B shared folder in published mode. However cannot delete or edit . Still Uer B can see. I worried. Its my very peronal.
Pls help
  • 4710 replies
  • February 12, 2024
Remove access by link and remove the user from the Share menu.
