I have 3000 components with these properties in the wrong order. Is there a way I can change the order without having to drag them into place for each component…
Also looking for a solution for this!
Found a solution! Apply Autolayout to the frame of all components with “Batch AutoLayout” Plugin. Then Stack all frames on top of each other with Griddle and select the variants you want to change (see screenshot). Then use arrowkeys to shift them within the component frame. This changes the default value of the property.
(Griddle is also a plugin)
