I need to create internal linking PDF exports; a multipage document with a table of contents that provides links to the relevant pages.
If I use the link tool, the links generated in the exported PDF go to the web URL of the linked frames, and does not navigate to the page within the PDF. Using prototype linking does not generate any interactivity in the PDF at all.
It would be useful for either the prototyping tool or link tool to generate interactive internally-linked PDF exports.
Hello! it seems that links inside PDF exports (to external sites) crash adobe reader. Would be great if we could get these links to work properly for export
Hi y’all. I m facing the same issue. Need to export to PDF and to keep interactivty links ( navigation in the document itself and external urls).
I know it is possible to use pitcheck plugin to do that. I did it a few times and now pitchdeck already require to buy a license. And it is way too much expensive considering the fact that i only need it to export interactivyt link in my PDF. $228 billed yearly just to export links ! Come on …
Please if anyone know a solution other than pitchdeck in figma to export PDF with interactivty links , let us know… There must be a solution in the native figma app to do that ?
I am facing the same issue. I wanted to design an interactive pdf file with link to the pages I need to hop on. If anyone has got any suggestion it will be really helpful!
This! I have been wanting Figma to make interactive links within the exported PDF for a long time. I know the Pitchdeck Presentation Studio is able to do this but it is very troublesome when it comes to big projects as they do not preserve the links and I’ll have to make them again and again. It will be great to see this feature being implemented
Pitchdeck is absolute trash, you can’t make individual elements link.
The easiest way I found is through Adobe Acrobat, although this may only work on the paid pro version:
Export your PDF from Figma
Open in Acrobat
Click “Edit Text and Images”
Open the “Link” dropdown and select from your options there. The auto create option didn’t work for me so I used the first option, “Add/Edit web or document link”… place a square over your button/link and away you go.
Figma making fully clickable, interactive PDFs exportable from within the app would be a complete game changer.
This worked for me. Yes, I had to do the linking all over again but it was quite fast to complete. I especially love that I could still do it within Figma, instead of exporting to Adobe Acrobat as advised by some commenters here.
If the prototype link can be exported as an interactive PDF that will be perfect. Then I can finish all the linkage in the main element. Or is there any plugin that can do so? I really need some help.
Yes please, add the native interactive linking to the PDF exports. It is a mess to do all the work on Figma and then to not be able to use it. For a planner, I need now to go with indesign or ther payd applications, it’s frustrating.
This would save so much time! Shareable/interactive PDFs are still a critical part of my workflow and recreating interactions in inDesign/Acrobat/etc. is very tedious. Please add support for interactions in PDF export!
The problem is with vector shapes (an icon for example), if it is a button with text or a simple text the solution is:
1 - select the text (Cmd+K).
2 - type the url in the input that appears
3 - go to text properties and remove the underline to the text box
4 - export PDF
Then the text links will be active to navigate outside the pdf viewer.
