Robyn_Wadey
Sep 19, 2023 4:53 PM UTC
Library updating bug
Is it possible to fix this library updating bug? I will make new components, extreme changes etc, and the file won’t detect any changes. It does indicate it knows there is a change though when clicked deeper.
Ryan_52
Ryan_52Solution
Technical Quality Specialist
Sep 19, 2023 7:07 PM UTC
The most common reason we see changes to a component don’t trigger an update is because there’s a conflict somewhere with a component you’re changing. You should see this conflict highlighted in the properties panel if you select the component as indicated by the (!) icon.
If you dont see a warning and you’ve checked your components for errors please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, share a short video showing the problem with the full window in view, include the links to the library file, and share it with support-share@figma.com so they can take a closer look.
Ryan_52
Ryan_52Solution
joelle.do
Nov 7, 2024 8:32 AM UTC
We encountered a bug while updating our library component. After adding an asterisk to a text field label, the updated label displayed incorrectly. Some labels turned black, and others reverted to default names. We need to manually reconfigure each affected field. Could you please assist us in resolving this issue?
Nov 8, 2024 6:49 AM UTC
Can you try “Repair component connections”?
If the issue persists, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
joelle.do
Nov 11, 2024 5:19 AM UTC
Thanks for your reply. Unfortunately, ‘Repair component connections’ didn’t work. I’ll submit a support ticket. Thanks again.
