I found many topics related to my question, but without answers and closed due to inactivity, so my hopes are really low, but give it a shot anyway.
Whenever I create a Layout Grid (columns) it will be visible, and work fine toggling the visibility with L Shift + G. but for some reason, eventually the grids will just not show… the toggle is still happening (the eye icon beside the layout grid toggle open and closed) but the grid is not visible anymore, and the only way to make it work again is to delete the grid, and create the grid again… which is a bit annoying.
Has anyone encounter this similar problem and had a solution? is this a bug that is beign addressed?
I will appreciate any type of answer, considering that most of the similar topics where closed without a single response.
Thank you!
Sounds like a bug to me…that I haven’t encountered yet. I noticed something in your post, though.
Do you use Grid Styles? At least that would be cutting the tedious part of creating the grid again, since you can just reapply the used Grid Style. They can be created and reapplied by clicking the 4 dots in the layout grid section:
Maybe that helps, cheers
Do you happen to notice any specific actions you take just prior to the layout grids not showing? If you open the file from another source such as the browser or desktop app while the issue occurs are you able to see the layout grids?
I would suggest reaching out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Try flipping your frame that you want to see the grid on. I’m on PC, on desktop client. I sometimes accidentally flip the frame (Shift + H) when I’m trying to toggle the grid (Shift + G). The Layout grid won’t show unless I toggle it back to its original position (which looks exactly the same, except now the grid shows up. Even when I delete and replace the grid it won’t work Until I flip the frame back to its original position. Hope this helps.
