Layer selection, while Prototype panel is active, is difficult
  • February 22, 2023
  • 190 views
While working in Figma with the prototype panel selected, I often want to create lots of interactions quickly across screens.
The ideal workflow would be: Select layer/s > drag the connector to create the interaction > then select the next layer and repeat
Instead, this is what I’m having to do: Can’t select the layer usually while in the Prototype panel so I have to go back to the Design panel > get the layer selected > go back to Prototype panel > drag the connector to create the interaction > again can’t select the layer usually while in the Prototype panel so I have to go back to the Design panel > repeat
Has anyone found a quicker way to make lots of interactions without having to switch back to the Design panel over and over?
